CarolynandBob
Feb 23, 2017Explorer
We are full timers. We currently have a class C. We are going to get a 5th wheel shortly. We went back and forth between a DP and a 5th wheel.
We ultimately decided on the 5th wheel because of the layout. We believe you get a better layout with a 5th wheel than a class A. Especially if you compare cost. We were not deciding based on cost. We were deciding on comfort.
Yes a class A is easier to set up and my wife can get up and use the rest room, make a sandwich or get something to drink.
As I said ours came down to comfort. We like the 5th wheels with 3 distinct areas. Living room, Bedroom and kitchen. We are most likely to get the blue Ridge 3888FL. We are only going to drive 4-6 hours at a time and stay a week on average, so a longer set up is ok. If it is raining, we will just wait to set up. We are retired so not in a hurry.
Now if money were the issue then you can get a lot more with a 5th wheel/truck set up. Just based on MSRP (which no one pays). The Blue Ridge is about 86K. Add a 70K truck to pull it and you at around 160K.
Now most of the DP we looked at we would have been about 190K plus a 35K jeep toad. Yes you can get a gasser class A for cheaper.
Everyone has different opinions and needs. The above set up will work best for us. As I said we are retired so that changes some things. We have more time to set up or add additional stops for food or restroom.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
