rthibodaux
Feb 26, 2015Explorer
heat pump/ac
I got 2 a/c's units and just wandering if it would be beneficial to change one a/c out and have one with an heater and a/c together. I know it use less propane but is the cost justified. Thanks Ran...
wildtoad wrote:marspec wrote:
I would wait until an A/C bites the dust. Since you have two you must have 50A service so one or two space heaters would do the job.
Not necessarily. You can have two AC units on a 30 amp system. Usually setup to run one or the other off shore power, both while on gen. From what I've read, a unit with a good power management will allow both to run, but have no experience on this one.
