golf_bears's avatar
golf_bears
AC with heat pump problem????
I have a new 2017 RV with a Dometic 15,000 BTU air conditioner. The AC is equipped with a heat pump. The heat pump was working great.
Now the heat pump trips the breaker after 3-4 hours of use.
I had a 2008 RV with a 15,000 BTU AC and a heat pump that gave me the same problem. Had it checked out a number of times but no one could fix it permanently.
Anyone else out there have a similar problem? If so were you able to get it fixed? If so, what was the fix?
Thanks in advance for any suggestions on how to fix the problem permanently.
