laknox wrote:
allen8106 wrote:
Jbird wrote:
Thanks again all. ( I would have gladly replaced the bearings before summer travel were they available. Lippert,Kodiak say they are no longer available. I have "Lippert" 8000# axles which may or may not be the same as Dexter 8000#s).
You don't have to buy the bearings from Lippert or Kodiak. Get the number off the side of the bearing and buy them at about any automotive supply house.
Any decent Timkin bearing is going to be better than the cheap Chinese junk that's likely put in at the factory. Personally, I'm not a fan of the Nevrlube hubs and, if I ever have an issue, all 4 will get changed PDQ to EZLubes. Never had an issue with them on my old, and heavier, Komfort, though I did have them changed after 10 years. They still looked OK, according to the shop, but I had better ones installed. Even without regular repacking, only annual greasing, there were no issues, but then I'm a "short hauler", and never put a lot of miles on my rig.
Lyle
From what I understand, this cannot be done with the Nevrlubes. You can replace the bearing cartridges but they must be Nevrlubes again. They are available; I just bought a complete hub assembly with the bearing cartridge pressed in to it to keep with me in case I have trouble on the road. While I was searching for it I saw just the bearing cartridges on line (I believe eTrailer had them).
