upsidedown_Char's avatar
Dec 13, 2016
propane heat
Our MH is equipped with two roof mount heat pumps. They seem to provide heat down to about 36 degrees.
We have a propane furnace in addition. We've run it about 3 times. The bathroom, hallway and bedroom have heat blasting out and the two vents at the front put out a tiny bit of heat. The floors get warm so heat is definitely passing through the front ducts.
There is a vent cut-off in the bath and in the bedroom vent. I have tried closing the vents in the bed and bath but that does not result in pushing more air to the front. There is no cut off in the hall vent.
Does anyone know if there is an adjustable baffle located anywhere on the floor system that will permit directing more air flow to the front?
I'm also concerned about damaging the floor system by blocking off vents in the rear.
We have some efficient space heaters that we can put on the MH to augment the propane system or maybe even eliminate the need for it all together. We will use that option unless someone is aware of a baffle adjustment in the duct system.
We are in the south and only need the propane system occasionally so I don't mind carrying the extra electric heater and letting the park cover the cost of our heat.
