- JIMNLINExplorer III
buc1980 wrote:
The RIB was a 2009 May be 16000 mile on them.I see a small buble on the side about a 50 mile from the destination but with 6 mile left on the trip it blow up.I think at SAILUN G637 now
Wise choice for your heavy trailer with as in your earlier post says 11800 lb on the axles.
Loads on trailers tires constantly change especially in strong side winds traveling down the road.
One tire blog showed loads on tires on the leeward side in a 35 mph side wind, could grow as much as 30 percent higher than the static load. - Me_AgainExplorer IIIWestlake Tires. Largest chinese tire company.
http://en.wikipedia.org/wiki/Hangzhou_Zhongce_Rubber_Company - calewjohnsonExplorer
Michelle.S wrote:
Not a recommendation as it's still a Chinese "E" (10 ply), but WestLake tires are now showing up as OEM on some heavier units and have a Load capacity just over 3500 so 7K axles don't have to be de-rated.
We have the Westlake tires. They look to be quite beefy, however, I ran the side wall around a curb and seem to have damaged the side wall, a slight bubble has formed. I am replacing all of mine with Sailun tires. The tire shop was surprised about the damage to the Westlake tires. They are popular with the contractors around here.
Cale - Michelle_SExplorer IIINot a recommendation as it's still a Chinese "E" (10 ply), but WestLake tires are now showing up as OEM on some heavier units and have a Load capacity just over 3500 so 7K axles don't have to be de-rated.
- buc1980ExplorerThe RIB was a 2009 May be 16000 mile on them.I see a small buble on the side about a 50 mile from the destination but with 6 mile left on the trip it blow up.I think at SAILUN G637 now
- Cummins12V98Explorer III
ol Bombero-JC wrote:
Cummins12V98 wrote:
If you want the "best" in a G buy the GY's. Top quality, US Made. They will pay damages. Their track record since 07 has been great.
E tires I would go with Me Again's recommendations.
Track record is *not* great - before or after '07 - research them where heavy trailers "live" - like on the SKPs forums.
GY *does* pay for repairs to damage done to your trailer..:C
Good reputation on that one - as it apparently happens often (especially with Marathons).
Does GY pay for your down time?..:D
EZ - solution:
Look for tires with a rep for *not* causing damage!..:S
I was NOT talking about Marathons. I stand by my statement. I have personally ran two sets of GY G's many thousands of miles without even a flat. I went to GY H's in 2012 they have been trouble free also. - Me_AgainExplorer IIINo tire is foolproof. Even 17.5 LRH tires are known to fail once in a while. If one does not have a TPMS you do not know if it was a run flat problem or sudden failure! Except in the case of hearing a load boom!! Chris
- ol_Bombero-JCExplorer
EZ - solution:
~ - Cummins12V98Explorer III
Me Again wrote:
Cummins12V98 wrote:
Say what? The tires I listed above are all Load Range G tires, rated to 3750 each.
Chris
I know I should have been more clear. I should have said "if buying E tires I would go with Me Again's recommendations" better? :B
He asked for a tire with over 3500 lbs capacity in 16", therefore there is no heavy duty(which he also asked for) E rated tire available. Chris
In know. It was a general statement. - Me_AgainExplorer III
Chris
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
