- jnharleyExplorerBuy a Trucker's Atlas at a truck stop. Any route a truck can go on, you can travel on the route safely too.
- ReneeGExplorerTrucker's Guide and overpass, bridge signs. We measured our fifth wheel both front and back, highest point, typed it on a piece of paper, laminated it and taped it to the front inside upper left windshield with another in the glove box for backup. With this, the driver can glance at it. You'd be surprised how easy it is to forget your exact height.
- fj12ryderExplorer IIIIf you're using a GPS you can get low height warning data base. It works pretty well. There aren't really that many heights below thirteen and a half feet in the country, all things considered.
- OasisbobExplorerMost are posted. This is useless information if you do not know the actual heigth of your rig. Measure
- 2oldmanExplorer IIUsually it's the sign on the bridge. Actually I have had this problem exactly once in 14 years.
- pjack01ExplorerThere are many RV GPS devices out there that allow you to enter the information size, weight, height etc. Then they will route you around any obstructions out there! Has worked very well so far
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
