olsond9's avatar
olsond9
Hello! Newb question here about $20k-30k 5th wheel
Hello all - Wondering about your opinions on a ~30' bunkhouse in the $20k-30k range. AFter reading other threads, I've come to the conclusion that there are not really significant quality differences in most of the options in this price range. And there's some debate about the quality of even the higher-end trailers. So I'm asking for your experience and recommendation for a good bunkhouse 5th wheel in this price range. We've found a couple that we're interested in but both are "lite" models - one only weighing about 7k pounds dry. Would we be better off with a heavier model (my truck and hitch can handle) for traveling across country? I get the obvious pros/cons about weight, but I'm specifically asking in regards to quality / durability. Seems less weight equals lower quality?
  • Buying based solely on price will always result in lower quality.
    20-30K is a low end budget if you are shopping new.
    My thought is even the higher end RV's are often flawed and poorly assembled however the low budget models are even worse.
    Light weight models are often made of lighter weight material which are not as robust and durable. In the end the light weight material impacts the longevity of the unit.
  • In general, I'd agree that lower weight = lesser quality but that is a generality. RVs of any price point are less quality than a stick built house. Some by a larger margin than others.
    Keep in mind the two main parameters when towing. How much can you carry? How much can you pull?
    Many folks just get stuck on one of those numbers and don't understand and/or like to ignore the other.
    OP's truck can pull a house but is pretty limited in how much it can carry. Especially if trying to stay within the artificially low 3/4 ton payload.
  • WTP-GC wrote:
    Rather than dig in on a new thread, I'd rather direct you to the other thread that's still active which basically asked the exact same question.
    I’ll try to find it. But I tried to search before posting this question and didn’t see it. I’m getting used to the forum.
  • Rather than dig in on a new thread, I'd rather direct you to the other thread that's still active which basically asked the exact same question.
  • Sounds like you have a 2500, if so pin weight will be your limiting factor. Look at loaded weights, not just dry. You’ll probably run out of payload long before you get to the 17k towing capability. As others have said, you’ll get much more for your $ if you can fall in love with a used model. If stuck on brand new, know that you should end up paying 20-40% less than MSRP depending on many factors.
    Good luck
  • Thanks. I have a 2017 Dodge Ram with Cummins diesel. Rated for 17k towing. I have an 18k fifth-wheel BW hitch. I was thinking I could push the weight limits a little if I’m on the flatlands in the Midwest.
  • Hi, we are on our 2nd 5th wheel in 9 yrs. I agree with your conclusion, lite usually does mean lower quality. As for brands, unfortunately all are going to have issues. The best advise I have had is buy used if at all possible, have the rig checked by a reputable rv center. One of the better bunks I have seen are the open roads and reflections. You maybe able to find a good used one on rv trader. As for towing, a very experienced rv'er told me try to stay 2K under your max towing weight. IE: my diesel 2500 is rated at 16K, my 5th wheel completely loaded is under 14K Hope this helps.
    What make model and year truck do you have?
