dave14117 wrote:
On road near Yellowstone, dw likes to cook and it's a little chilly at night. For our 06 Cougar 5'er filled both propane tanks yesterday but since then cannot get any gas to flow to the trailer. Red/green indicator stays red. Smelled a little propane near the tanks occasionally before the refill. Have tried the very slow opening thing with no change on both tanks individually. Turned the water heater electric option off to have something open in the gas line.Original regulator and tanks. Nothing helps. Thinking need new regulator. Or maybe one of the gas feed tank-to-regulator lines. Any suggestions appreciated.
Likely the excess flow valve on the tank has shut off. Shut off the tanks, open the stove valves to allow any propane to escape. VERY SLOWLY open your tanks and try it again. You might have air in the lines, so it may take a while for things to light off.
Lyle
