Allistah's avatar
Allistah
Help Choosing TV (By the numbers)
Hi everyone..
We will be getting a new 5th wheel next year and I am making all the effort up front to get the right TV with the right hardware to which will end up in a great tow experience.
The 5th wheel that we will be getting is the Coachmen Brookstone 315RL. These are the specs for this unit:
  • Hitch Weight 2,350 lbs. (1,066 kg)
  • Base Weight 11,230 lbs. (5,094 kg)
  • GVWR 14,500 lbs. (6,577 kg)
  • Cargo Carrying Capacity 3,270 lbs. (1,483 kg)
  • Exterior Length 34' 8" (10.6 m)
We will also be towing a jet ski trailer behind the 5th wheel with three PWC on it which will end up being about 2000 lbs. max.
Now for the TV. We will get a Chevy 3500. What I don't know is what config of that TV will be required and how to absolutely know without any doubt that I have enough TV to pull that 5er plus the 2000 lb. jet ski trailer without being overweight and ultimately - unsafe.
I've read a lot and the numbers are all over the map and very confusing. Most of the time I've been looking at the GCWR of the truck and then the GVWR of the truck and trailer itself and it almost always goes over the GCWR. Then I see people say that it's very difficult to get under the GCWR.
How do I make a Chevy 3500 TV safe to tow the 14,500 lb GVWR 5er plus the 2000 lb PWC trailer and be safe?
Any help here would be appreciated.. Thanks!
