Double-Trouble
May 05, 2013Explorer
You can turn the tubes 180* so the scratches aren't on top and you will be fine. You may also want to check with Superglide as the new ones have Teflon that they ride on, eliminating the need for grease or slip plate.You may be able to upgrade to the new system.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
