RVhiker
May 05, 2013Explorer
My Superglide 4100 uses Slip Plate (actually, I use another graphite paint called EZ-Slide).
I've thought about converting to the plastic wear plates, but even then don't you have to use a light oil application to the way tubes? To me, this is not much improvement over using the graphite paint.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
