mapguy wrote:
The power converter is part of the electrical panel or "Power Center". It is a 110v device wired to one of the 15 amp breakers in your Power Center. Easiest way to gain control of it is to add another breaker to your panel for the power converter only. Then you can turn off and it is available as a redundant system to an inverter/charger if it fails.
On Page 3 of the Eclipse Brochure -the Power Center is below the Refer in the cabinet for reference:
http://www.eclipservmfg.com/media/AttitudeCata-022113WEB.pdf
Thanks! I just opened up the power center and located it. The convertor is connected to a breaker so I can just flip it off.
Also, when I go to install my inverter/charger....can I just connect the DC connection of the inverter/charger to where the old converter was connected?
