goducks10
Nov 03, 2014Explorer
If you're having trouble with a 23' TT then you either don't have the WD setup right or your tow vehicle is undersized. I towed a 22' TT with an 08 F150 and literally did not know it was back there. I currently own a 5th and it's the same feeling. You feel the tugs from it once in awhile like you should but as far as sway goes it's non existent. It cuts corners a little sharper, it's a little trickier to back in and it's taller so I have to be a little more careful. A 5th only has one advantage over a TT and that's towing down the road. The rest is all personal preference.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
