MFL
May 24, 2018Nomad II
Yes, it could be a bad switch. Do you have a meter/tester and know how to check switch? You could just jump across/bypass switch to see if motor turns. It could be the motor too, or a loose wire connection to the motor. You just need to follow the wires to check for current, or lack of current.
Jerry
Jerry
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
