RustyJC wrote:
You really need to take a look at the current B&W Companion RVK3500. Unlike the old 18K rated Companion, the 20K rated RVK3500 bolts to the sides of a much beefier adapter post and uses the vertical bolt to "pinch" the release pin in the B&W Turnoverball gooseneck hitch. In my case, this is irrelevant since I use the 25K rated RVK3600 that mounts in the factory Ram 5th wheel hitch prep pucks, but if one is going to critique the Companion, it's most accurate to direct the criticism at the current model.
Rusty
You mean like the 3500 I just switched over from my 2013 to my 2016 last night?
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
