big_bird_2
Aug 22, 2013Explorer
I have a "Plug It Right"; which is similar to JT, only not as expensive. It is a simple to moderate DIY project. Keep in mind you will be on your hands and Knees every time you lower or raise your FW and you will still feel some movement. If you want to do it right, you need a 6 point leveling system. You get a jack, leveler and stabilizer all in one. These are somewhat new to the FW market and true to the RV industry cheap comes before quality. A modification system like "Plug It Right" is under $300. A 6 point is $4,000 to $5,000 and you will find it a skilled DIY project.
I never had a stabilization problem with my backpacking tent!
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
