willald
Aug 18, 2023Explorer II
stabilizing power steps
We just got back from a trip, where I had the power step motor quit in such a way that steps became free moving.  The gears inside motor had stripped a tooth or two, allowing steps to move freely.  Made it impossible to get in or out safely (argh!)
Until I could get the motor replaced, had to stabilize the steps somehow. Soooo, I went to Lowe's, bought a bunch of 2x10 and cut it into squares, stacked them and some wood shims underneath bottom step to hold them in place.
This worked great and held the steps in place until we could get the motor fixed. I learned from that, that with the bottom step stabilized like that, it makes things much better. Motorhome doesn't 'wobble' at all now when someone goes in or out the door, and step feels much more solid. Also, I think it may extend the life of the motor some, by reducing the stress on those gears if the steps are held in place when parked.
Want to find a good way to do this (stabilize the steps) when parked, but without having to carry and mess with a whole lumber yard of wood squares and shims, haha.
Has anyone figured out a good way to stabilize their power steps, so they stay in place? I don't want anything that permanently attaches to the steps, as I think that would be asking for worse trouble. That rules out a couple options made by Lippert, I know. Maybe something as simple as jack stands, but seems those are too big to fit under bottom step. Any ideas?
I realize that if I do this, I will have to make dang sure whatever is down there stabilizing the steps comes off before power steps ever energize, try to retract (otherwise you'd burn up yet another step motor very fast). We keep the steps off so they only would go up when engine is cranked up, so thought if we do this, might put a sign somewhere on the dashboard, reminding one to make sure steps are free before turning on ignition..
