gbressler's avatar
gbressler
Help me understand my GVWR
I have a 2015 Chevrolet 2500 4x4 Crew Cab Diesel Standard Bed truck and currently tow an 8,000 lb TT effortlessly. I am now looking at fifth wheel campers and here is what I cannot understand.
GAWR Rear @ 6,200 lbs
Combined rear tire rating @ 6390
Had the truck weighed rear axle weight @3,220
Looks good giving me about 3,000 lbs available.
Chevrolet specified about 3,000 lbs pin weight for my truck and it all looks good from this angle.
But here is a different approach and I can't understand it.
The Truck GVWR is 10,000 lbs.
Our truck weighed 8,100 lbs
This only leaves 1,900 lbs without a fifth wheel hitch.
So for me these numbers just don’t add up. I don’t want to tow at max capacity and don’t want to exceed my vehicle GVWR but how does GM specify 3,000 lbs when that would exceed the truck 10,000 lb GVWR? Please advise.
  • Where does Chevrolet specify 3000 pin weight, I believe you are reading between the lines. if axle is rated at 6200 docent mean rest of truck is. Some states different to others.
    Frank.
  • Just wait the weight police will be here shortly. For good information go to the thread sticky in tow vehicles about weight law.
  • GVWR at 10,000# is a cross over point. At 10,001# some states require a commercial drivers license to operate the truck. Hence the 10,000# GVWR. Some will tell you that the manufacture listed at 10,000# because there is the entire drive train just not the rear axle and tires to take into account.
    My 2004 F350 has a GCVWR of 20,000# which means my 8,000# truck leaves me a tow capacity of 12,000# trailer. If you look at the numbers you can go from gas to diesel and it stays at 20,000#. You can go from 3.73 to 4.10 rear axle and it stays at 20,000# you can go from SRW to DRW and it stays at 20,000#. Move to the 2005 truck and now you get credit for all these things.
    As long as you are not pushing the truck to it's limits you should be fine. I roll through PA on I-80 with my 12,000# 5er, cruise set and enjoying the view.
    This is just my opinion and sales people write the brochures and legal people write the door stickers.
