riggsp
Aug 19, 2014Explorer
Check the wire size from the battery to the hydraulic pump...it may not be large enough to carry the load. Also check the wiring to the switch. Does the switch operate a relay, then the relay to the pump or does the switch connect directly to the pump? I would make sure the switch operates a relay, then have adequate sized wire from the relay to the pump. JMHO.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
