Vanhollymorgan
Aug 19, 2014Explorer
Lippert swears up and down nothing in motor that would do or cause that, my bet was on the auto reset, I was on a three way call with lippert and heartland for an hour and still no idea. Other thing they are both sure of is my warranty ran out three weeks ago. Heartland keeps going back to battery, lippert says its the 50amp mini fuse inline.
I've replaced that though.
They both agree the voltage should not be dropping on the LCD and my multi meter as the slides and legs come in.
There is very little drop as they go out.
I hooked truck up with 7 way and turned on so that had the voltage at 13.5 dropped to 11.2 and cut off.
Shore power close to same way.
Battery only went from 12.7 to 10.6 and shut off.
I put multimeter on battery and on the pump both and noticed the same drop as it was running. I think it's the motor it just seems to be drawing to much power. But lippert says only fuse or reset is inline that I've replaced.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
