Help! New to fifth wheels but had TT with Hesley Arrow previously. I've read all the manuals that came with the hitch, read as many posts as I can find but still can't find my problem. I've had no...
Simple, it happens all the time. Just raise the RV up until the weight is off and maybe a bit more. If you pull the release and it's hard, make sure the RV is chocked, get in the truck and put it in reverse with your foot on the break. You may have to let it move reward just a bit, not the RV, just release the pressure. Then put the TV back in gear and pull the pin.
