Ricpin
Dec 04, 2014Explorer
Help with a TV
My wife and I are planning to purchase our frist 5th wheel.We have decided on a Montana 3750FL. If anyone owns one please tell me what you use for a TV. Do I need a DRW or can I get a SRW drive Pick U...
C-Bears wrote:spud1957 wrote:
C-Bears, the only 2012 F350 6.7 that has a "published" payload of 4400lbs is a 4x4 regular cab XL. I'm sure that's not the truck you have, so your payload is probably less than 4000lbs. You could share with us the your actual payload rating on your door post. This will give us and the OP a better understanding of the variety of truck ratings and specifically an F350.
S
You are probably very familiar with your 2011 Ford specs, and you may have even looked up ones for newer Fords, I don't know. I will help educate you though. A 2012 F350 XLT 4x4 CC SRW 156" Wheel Base, with optional 11,300 lb GVWR Package, specs out with a payload of actually slightly over 4,400.
But again, none of this really helps the OP with his exact question, although it is entertaining.
