kkirt1 wrote:
Thanks for the advice. Still curious as why for the first few years it didn't seem to be an issue. Now very noticeable. Wondering if there is something about the settings (temperature, fan speed, fan mode) that has started this humidity spiral.
As to fan mode, I have noticed when fan is continuous on my Dometic 15K, the humidity level will rise after compressor shuts off.
If I set fan mode to auto, and the fan and compressor shut down, the humidity stays where it is at shutdown. I also notice a burst of water drainage from the roof gutters.
It may be possible, on continuous fan, that the fan is recirculating some of the moisture in the bottom of pan??
Do you have/use auto fan setting on your units?
Jerry
