pcm1959's avatar
pcm1959
Explorer II
Nov 30, 2014
Help with MorRyde Pin Box
I wanted to post this to see if anyone else has had any problems with their MorRyde pin box. I have contacted MorRyde and sent them the same video that I have enclosed a link to in this post. I am contacting them again tomorrow but in the meantime, I'm interested to see if anyone else has experience the same.
I have a 2014 fifth wheel that weights in at 15320 lbs. for a typical trip with a pin weight of 3400 lbs. I purchased the unit new equipped with an optional MorRyde pin box.
My towing experience is very poor in stop and go traffic and I'm experiencing some chucking under way. Even just backing-up and pulling back and forth the noise and "banging" in which I can not only hear but feel passed on through the truck is awful.
I have made marks between the pin box and on various areas of the trailer frame to make sure that there is not a compromise in the trailer frame. That has proven (thank goodness) A-OK.
I have checked the fifth wheel hitch frame brackets and rails for any play or loose bolts......all good.
I have a Trailer Saver hitch with positive locking jaws. They are very tight.
I have explained all this to MorRyde via email and actual conversation as well as sent them the below video. They don't feel the movement is extreme but are puzzled by the noise.
They sent me a new spring (a number 5) and I installed it. Made no difference. I told them that but still no solution.
It is so annoying and unnerving. At every stop and start there is all this play, slop, and noise.
I have owned 2 other trucks and 2 other fifth wheel trailers and never experienced anything like this. My previous fiver had a MorRyde and it was fine.
I was camping this weekend and a neighbor with a MorRyde (2008 year model) looked at mine and said that there is a plastic spacer missing between the sides of the skid plate and the round bars where the rubber shear pin is located. Also, there are holes on the outer edges that hold these white plastic spacer in place. I have the holes, 2 p/side, but not spacers. I thought he was on to something, however, looking around on-line at new ones, I do not see this part.
I hope all this makes since. Please watch the video and give me your thoughts. Its driving me nutts!! Thanks, Phillip
https://www.youtube.com/watch?v=hWVJam7rG8M
