We just purchased a Lifestyle LS36FW. It has a @30ft slide out. If I am running it in or out and I stop It takes about 15 minutes before I can resume. Anyone know what's up with this?
There is a high temperature cut off relay in the circuit that could be defective and interrupting the power early. They are usually mounted on the wall of the battery compartment with the wiring to the hydraulic pump. Mine started doing this some on an older (~10 year) trailer, not because of the relays, but probably because the rubber seals were old and stiff. The problem was worse in cold weather.
