thefishingal's avatar
thefishingal
Help with slide out
We just purchased a Lifestyle LS36FW. It has a @30ft slide out. If I am running it in or out and I stop It takes about 15 minutes before I can resume. Anyone know what's up with this?
  • We just bought new batteries. No luck.
    Husband says it's not a hydrolic system. It's mechanical. Do you think there is a relay in this type of system?
  • There is a high temperature cut off relay in the circuit that could be defective and interrupting the power early. They are usually mounted on the wall of the battery compartment with the wiring to the hydraulic pump. Mine started doing this some on an older (~10 year) trailer, not because of the relays, but probably because the rubber seals were old and stiff. The problem was worse in cold weather.
  • If you have a generator, start it and see if you have the same problem. If you don't, it's most likely your batteries.
    Bill
  • Slides basically are powered by your battery....Is it fully charged and in good condition?
