waltbennett wrote:
We were over 8k at two different overnights on our current trip to the west coast from Virginia and ours worked fine. Had a little bit of issue with it freezing when the outside temps hit 114 in Northern CA though. IMHO it's really about pushing things to the limits of their capabilities.
I have to keep ours on max cold all the time and it is barely cold enough. Never will it freeze things....other than in the freezer. I wonder if the temp it goes to can be adjusted? I have the little hose inside pushed as high as it will go for coldest 'setting'.
