My friend is needing a favor from me.my Reese hitch is a 16k and he is needing a grand design brand momentum toy hauler moved from San Angelo to gilmer.the specs say it has a 18k+ GVWR but it has only...
Vehicle weight is pin weight plus axle weights. Your hitch should be rated in excess of the actual towed vehicle's weight.
Your 16,000# hitch should work if they have not loaded the trailer past 16,000#. A trip to the scales would be in order. We added around 1,500# to ours so if someone has been living in it, you probably need a larger hitch.
