sayoung wrote:
It's just one time but I have already said no.i don't need a bigger hitch.i probably would have no trouble since its only got 16k worth of axles but his wife probably has that much stuff packed into it.those light axles make me think its not as heavy as the mfg says.
I just feal bad not doing it
1. You don't need a bigger hitch. Probably 4K of that 18K is for water, storage bays, clothing, food, etc. If they'll unload it of personal items and drain the tanks, you should be WELL under 16K -- even well under 15K. They don't need to remove the furniture, just everything else.
2. 5ers carry weight on their axels AND on the pin. Two 8K axles are plenty for an 18K 5er. Of that 18K pounds, probably 3.5K is intended for the pin, leaving a little to spare for the axles.
3. The manufacturer is not saying the 5er weighs 18K pounds; it's saying that's the maximum that it CAN weigh all loaded up with batteries, water and personal items. They assume you're going to load it, and big full-time rigs have room for quite a bit -- probably around 4K pounds.
If you want to tow it for them, simply tell them they must remove all the personal items and drain all the tanks first, so that your hitch can handle it. And then make sure they do. And double check by weighting it before leaving town, if you have any doubt.
