Here is a possible low cost solution.  Install rails and use your Patriot hitch.  Buy a BedRug bed mat for around $200 and cut out openings for the rails.  The mat is thick and will raise your bed to about the top of the rails.  Things like lumber and large items slide right over the rails when pushed in.  You get the added advantage of having a soft floor to crawl around on.  I would also get the additional tailgate mat; a soft seat when you need one.
This is not a good solution if you want a clean bed to haul gravel, bark, or other loose items that need to be shoveled out.  I have rails and a BedRug in my truck and I love it.  It is 18 years old and still looks great, however I run a tonneau cover and my truck is pretty much a dedicated tow rig.  When I need gravel, I have it delivered..
