All. Quick question. You would think I could make my own decision on this, but I turn to you guys for a bit of advice. I am upgrading both my TV and 5'er. The new TV has an under bed mount for th...
Like anything that is weight rated, you'd expect the higher rating to be built stronger.
Usually the heavier weighted model will also have a higher pin weight rating.
In your case any of the three would work. If you have the Ford FW prep package, I would suggest the B&W for Ford OEM. It is a great hitch, and rated for 20K.
