rhagfo
Dec 07, 2013Explorer III
hermandutchman wrote:
If you mean at a 90 degree angel, then yes you can. The big problem is that when you pull away you will put extreme twist on the tires which could damage them, also could damage frame.
WHY, WHY do so many think the suspension under your 5er is made of glass and will be damaged the first time you look at it side ways! Not something I want to do every day, but will not damage the frame or suspension, not the best for tread life as it will create a lot of tread scrub. The biggest issues would be the strain on the Landing gear, this is the one case where I would have the pin box and the hitch very close to the same level.
About Fifth Wheel Group
