Cummins12V98
Dec 07, 2013Explorer III
hermandutchman wrote:
If you mean at a 90 degree angel, then yes you can. The big problem is that when you pull away you will put extreme twist on the tires which could damage them, also could damage frame.
If damage happens in that situation then the tires and frame were not worth having. JMHO
About Fifth Wheel Group
