filrupmark wrote:
Here is a tip that makes setting your fiver hitching height very easy. After disconnecting adjust the length of your brake cable so it just touches the ground. I used some small stainless chain with a brass snap connector on the end. Then when your ready to hitch up drop your cable down set your height and back in. Works every time very smooth.
Sounds interesting. Can you give a little more detail on how to set your cable up and then drop your cable down to set your height? Do you mean "after disconnecting? Do you mean unhooking your 5th wheel from the truck?
