aruba5er
Feb 04, 2014Explorer
There is an aftermarket device made by Reliance that bolts to one Honda 2000i and has a 30 amp RV outlet and 30 amp curcuitbreaker then you plug in the attached bananna chip leads and you can use both at the same time. Kinda like the Companion but with the right outlet and a breaker. A Honda dealer should be able to get this for you Mine did. Better than using an adapter. And why doesn't Honda use the RV outlet instead of the twistlock it does???? And google Honda extended stay tank and make yourself one.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
