SoundGuy wrote:
Progressive Industries is a big supporter of the author of The No Shock Zone yet specifically warns against source bonding when using their EMS products with that source.
From the article I linked:
That’s why you need to provide your own G-N bond when powered by a “floated” portable generator using your shore power cord. I’ve already confirmed this with the engineering department at Progressive Industries as well as tech support at Honda Generators. Looks like it will take a major NoShockZone campaign with NEC references to get the point across to these generator manufacturers. In the meantime, you just need to build a simple Edison G-N bonding plug to allow your voltage/surge protectors to operate normally.
Rusty
