Espee
Feb 25, 2017Explorer
Honda generator noise mitigation
I have a Honda 2000 generator that I am experimenting with while operating it in the front compartment of the FW (adjacent to battery box).
Looking for ideas how to keep it from transferring vibration to the thin sheet metal compartment bottom. Maybe a 1/4" or thicker plate steel base would help? I put it on a 1/2" cushioned floor tile with a piece of carpet on top, but would like a little better isolation... Ideas?
FWIW:
It is easy to start by leaning it over a bit (so pull start clears the lower lip of compartment).
I can use a one gallon fuel can to transfer fuel onboard fairly easily.
I am looking into an exhaust flex extension to make sure co2 goes outside, even though the plan is to run it with the compartment door held open.
Anyone else had experience with a similar configuration?
FWIW:
