bucky wrote:
The propane fireplace in my house has no vent to the outside and certainly meets code because I checked when we moved in.
I probably would have vented it out the side but I see no problem with the way it is.
You're talking about a vent-less appliance that has an oxygen depletion sensor and has been UL tested and approved. Installing a generator that burns fuel at a MUCH higher rate in a confined space with limited fresh air supply is an entirely different setup. And that's just the beginning of all the things wrong. Over-sized vent material, improper downward slope, does it just discharge under the trailer?
With all the threads that get shut down here for no reason I'm surprised things like this are allowed to flow so freely. Every other trade board I frequent would have that picture deleted in an instant.
