mickose wrote:
I am looking at Honda generators and they have a EU2000i and a EU2000i Companion. The difference other than price is that they advertise that you need the 2000i companion if your running two units together. I only plan on using one unit when boon docking and that would be to make coffee or charge up the unit battery a bit. Am I correct in assuming I only need the 2000i, not the companion model. Thank you.
Suggest you spend some time - use the "search" feature - on the *TECH ISSUES* forum (here).
Forum is listed under the "Technical Resources" heading.
Everything you wanted to know about generators - and then some.
Opinions, experiences, info etc. - for all the brands known to man!;)
