meleavingsoon
Jul 25, 2017Explorer
Ivylog wrote:
A lot of variables...if you put 45 degrees corners on the bumper it can be further back. How far behind the rear axle are you putting the pin? Are you putting a bed on the truck?
Thanks Ivylog....those are questions I am still thinking thru. I think I will ultimately install a flatbed.
I know I will ultimately have to decide because they impact my decision. For now I am thinking I will locate the kingpin directly over the rear axle.
I measured from the center of the kingpin and have 66" of clearance before touching the front of the trailer. I was also thinking I could take a 66" long stick and swing it around from the center of the hitch while sitting on the frame rails and always know what would work to clear the trailer.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
