Gray_Fox's avatar
Gray_Fox
Hot water smell
What could be the cause of a smell when drewing hot water. Our fifth /W was left for repairs all winter, we picked it up today an noticed the smell. I don't think the hot water tank was drained out for the winter. What do you use to get rid of the smell???
  • If your from MA and the rig was not winterized is the rest of your water system ok? Try http://www.rvtechlibrary.com/plumbing/sanitizing.htm for tips on how to sanitize your RV water system.
  • The water in the tank has bacteria growing in it, having been sealed up for so long, it went anaerobic, and that smell is what happens. The solution is to flush out the water system with water containing a little bleach, let it sit for a few hours, then flush thoroughly until the chlorine smell is gone. I believe the recipe is a cup of bleach to 10 gallons of water. Put it in the fresh water holding tank, pump throughout the system and let 'er sit.
