bob213
May 05, 2017Explorer
Highest amp hr I can remember on a 12v battery is around 85 for a group 24. You can use about half of that before your battery is dead. If you add another 12v group 24 you will be up to 85 amp hrs. As someone said earlier 2 6v will give you about 110 usable amp hrs. If that battery disconnect switch is a 2 battery on1-on2-both-off switch that may explain the extra red wire.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
