prelucir's avatar
prelucir
How do you carry your bicycles?
I have a Big Horn 3575 EL. I want to take my bicycle when I go places. However, I am not sure how to carry it with me. I don't think I can squeeze it in the back of my truck. I do not have a hitch on the back of the 5th wheel. They told me that if I put a hitch on it, that would negate my warranty. The dealer told me that I should not strap them to my ladder on the back as the constant jarring when going down the road can work the ladder loose.
Any suggestions?
Thanks,
John
  • Long bed or short bed?
    I used to remove the quick remove front wheels and lay two adult bikes in the bed in front of the hitch of my long bed. Later I made a pin box bike mount. Mounts using pin box bolts so no mods required to my 5th Airborne pin box. Easier and quicker and keeps the bikes up and out of the way when not used. Can carry three, and maybe four, bikes. Don't know that either would work if you have a short bed.
  • Bessie-Hunter wrote:
    Front hitch on the truck for the bike rack.
    X2
  • We use a Curt front mount receiver on our truck along with a Swagman XC2 bike rack. It took less than an hour to install the receiver using existing frame holes. I like being able to see our bikes. And no it does not block our view of the road or effect cooling at all
  • 4x4ord's avatar
    4x4ord
    Explorer III
    Years ago I built a 2" receiver hitch for my 5th wheel to accommodate a 6 bike carrier that I also built. It worked very well.
  • $600 for a class 3 hitch welded to the frame. Standard hitch bike carrier.
  • If you search the forum, you'll find many posts on this. Find a good hitch receiver that bolts or welds onto the frame of the fifth wheel. DO NOT use a receiver that uses U-bolts on a square bumper - you will end up dragging your bike(s) down the road by one weld or a security cable. Our fiver came with a frame-mounted receiver and we have an RV-certified Swagman bike carrier with our two comfort bikes on it.
    Rob
  • I disagree with Bessie. A quality bicycle should never be carried on the front of a TV.
  • What warranty? If your trailer is more than a year old warranty is probably over. I built a bolt on hitch platform and pads for the rear stabilizers. The original pads were flimsy sheet metal boxes that bent after one trip. So it was a no brainer. Worked for 13 years for me with only one issue. Bought a decent hitch mount bike rack. As an option years ago we had a bike stand that we placed inside with 4 bikes. When we got to our site it went outside for the bikes to park.
