- rmalik1Explorerhave fulltimed in the past and will again in the future. 15.5k dry which doesn't mean much, loaded we weight about 18k - Go to Escapee's smart weight and get checked then u know for sure; peace of mind for 55 bucks & thats w/ everything filled up! We don't stay at parks (to often) so it's not that important to us as long as we are close to what we want to see. MPG also is the cost of rv'ing so if it's 8,10,15 mpg then thats what it is. There are ways to reduce the hit u take in $ dependent on the length of time spent on the road and the length of time it takes u to get from point A to point B.
As for the problem w/ big rigs u get use to figuring things out. U will use a motor carrier road atlas, a good trucker/rv gps, extra fuel capacity with in-bed or replacement fuel tank or MDT truck, I've f350 psd,lb,crew cab,dw with a 50 gal in-bed transfer flow, dezl 560lmt, and don't have to worry much about finding fuel stops etc. I'm 6 feet shorter than a 53 ft tractor trailer rig so I go were they go for fuel and vittles !!! - janegowestExplorerNot very heavy for a 41'. That's great!
- kakampersExplorer
janegowest wrote:
kakampers wrote:
We fulltime and tow a 41', 17,600 pound Landmark with a 4,200 pound pin weight. We tow with a 2011 Chevy 3500 DRW and get 10-11 mpg....
Is that the dry weight?
No, that's loaded...dry weight was 13,864 lbs. - RedJeepExplorerForgot to mention... 8.5mpg, but mostly hill and mountain driving. My truck is older but drives great in my current configuration. 2001 7.3l diesel dually and 15-16k lbs for my toy hauler.
Is that the dry weight? - Cummins12V98Explorer III
TXiceman wrote:
Cummins12V98 wrote:
TXiceman wrote:
Cummins12V98 wrote:
Proper TV not a problem! 28K+ combined 9.5 hand calc West Coast average. Dry weight means nothing. Look at combined weight rating then take up to 25% of that to calculate your pin weight. Mine is 4,500#.
You might want o explain what you are taking 25% of to get your weight.
For a typical larger 5th wheel trailer, your loaded pin weight will run around 20% up to maybe 25% of the TRAILERS GVWR...not a combined weight.
25% of your listed combined of 28,000# is 7000#.
Ken
I could be a smart AZZ I suppose and say what is 4,500# 25% of but my RV weigh is at least 18K and probably more since I last weighed it so the answer is 25% of my RV's total weight 18,000# is 4,500#.
Go back and read exactly what you wrote.
I am not arguing, just wanting to make sure the readers get truthful information.
Ken
I see you could read it two ways.
I should have said. "Look at combined weight rating OF THE RV then take up to 25% of that to calculate your pin weight"
Thanks! - TXicemanExplorer II
Ken
Ken - Cummins12V98Explorer III
Ken
I could be a smart AZZ I suppose and say what is 4,500# 25% of but my RV weigh is at least 18K and probably more since I last weighed it so the answer is 25% of my RV's total weight 18,000# is 4,500#. - soosExplorer IIOur 5th wheel weighs in at just under 18,000 lbs.
We tow it an average of 10,000 miles a year and get an average of 11 mpg while towing. As mentioned, wind can be your enemy with fuel economy.
With duallies, the trailer pulls like a dream. and the truck barely knows its there. with so much rubber on the road, big rigs passing by don't affect us. - mabynackExplorer IIThanks for the tire info. I'm thinking of going to G load-rated tires before my next long trip. Not only are blowouts inconvenient, they're expensive and they never happen at a good place or time. My last one happened in the middle of Atlanta and the two before that were in Charlotte and Columbia, SC. All around rush hour. All three blowouts happened with tires that were only a year old.
The four E-rated tires on my RV are rated for 3500 lbs each. That means the four of them together are rated for 14,000 lbs. That's just under the gross weight of my RV. I realize that some of that weight is on the truck, but apparently not enough of it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
