Wood_chip's avatar
Wood_chip
How many here have tailgate clearance issues
I posted on another site as well.How are you dealing with the tailgate clearance with the front of the coach while the tailgate is in the down position ? Currently I moved my B&W companion to just behind axle to help this condition but I’m thinking of purchasing the Trailersaver BD5 which has no front to back adjustments. It seems while hitching up, one would have to start with the tailgate down and once the pin box clears the tailgate then to raise the tailgate. That may be the norm but is something I have not had to do.
  • I cannot open my tailgate while hitched. It is not even close.
    And I don't think it has anything to do with long/short bed, or with brand of hitch. It is all about the design of the fiver and how much overhang they built into it. I simply have more basement space than I would have had if they had built more overhang, within the given coach length.
    A Vee tailgate solves the issue for me. Tailgate stays up all the time.
  • Lenny K wrote:
    Probably more to do if you have a long or short pin box that people have or have not this problem.
    I already have the MorRyde extended pinbox. Short pinbox would be impossible
  • Probably more to do if you have a long or short pin box that people have or have not this problem.
  • chag67 wrote:
    I have a F350 long bed and the tailgate down clears my Grand Design Solitude 379FLS with no problem, even when connecting at a 45d angle.
    The trailer overhang at the bedroom area must be much different from trailer to trailer. I guess this would be the biggest of the reasons for tailgate clearance issues
  • Anonymous's avatar
    Anonymous
    Approved
  • My F350 long bed tailgate clears the front of my Montana by about 4”. Have to be careful to be close to straight on when hitching. Reese Elite hitch about an inch in front of axle.
  • Long bed truck
    Can open tailgate when hooked up to 5vr
    Hitch is actually 2" forward of centerline of rear axle
    Other then Opening tailgate to hitch/unhitch the only issue is to remember tailgate is down when leaving.........turns would make tailgate into a can opener on front compartment
    (One reason I swapped to a 'U' 5vr tailgate vs OEM)
  • OP here . I guess one could put a strap on the tailgate to hold it up at the midway or at least below the the height of the hitch while hitching/unhitching
  • I found that w/ our Big Country, the front of the coach (basement) door isn't as angle back as old Silverback was, thus we lost the space you are referring to. Kinda stinks and we too turned the base of the Patriot around and while we gained some add'l clearance, nothing like w/ the Creek.
