rhagfo wrote:
smithrjd wrote:
TX iceman, yep that is what I have, the Dexter axles. Going to need another tube or two of grease..
If you put even a half tube of grease into the four hubs, you will likely grease the brakes.
I have that system and have pumped many tubes of grease into them and NEVER had a bit of grease come out the back. I have disk brakes so it's easy to tell.
Use quality synthetic that will flow easily. DON'T use a pneumatic grease gun.
Have someone spin the tire and pump as fast as you like and the old grease will start coming out. Simply wipe off and when new grease appears you are done.
For this system to work properly you need QUALITY seals like National.
