Ron3rd wrote:
The center hub on the ez lube hubs is normally dry initially so it takes A LOT OF GREASE the first time. Easily half a tube. You pump the grease in until you see clean fresh grease come out the end. I use the red grease to see this easier. The next time you'll use much less grease because the center of the hub is now full. There is no set number of pumps. Plenty of YouTube videos to show you how.
Rotating the wheel while you're doing it is a must.
Yes, good description!
Just as a reference, my current FW needed 50 strokes, each hub, to fill the bearings and hub cavity. My FW has 5200 lb axles. I did use nearly 2 cartridges of grease.
People say waste of grease. Maybe, but even good quality grease is cheap. I buy a case at a time, from distributor, for my 3 trailers. I hand pack at times, when pulling a hub, but never feared using the zerks.
In my experience, a hub filled with grease, will run about 10 degrees warmer. Not an issue IMO.
Jerry
