laknox
Mar 03, 2016Nomad
mtofell1 wrote:
Is it just me?? I just expect the things to break every time I push the switches. And it's not just this RV (2016 Keystone Hideout). My old Salem scared me as well.... although it seemed a bit more smooth.
The whole slide just flexes and moves in what looks like scary directions. It seems like the top moves at a different rate than the bottom at the beginning and end of the range of motion. The slide floor lifts a couple inches when closing completely, and settles into place a couple inches when extending completely (both in my 5th operate the exact same).
Maybe I just worry too much... I have a warranty. I'm just afraid of trying to drive home with the slides extended :)
Currently, I only have 1 slide. I marked its depth, plus 3-4", on my awning pull-down rod and just use that as a gauge to be sure I have enough clearance before I put the slide out. Check any obstacles I'm not sure of (knee-height and overhead) and, if I'm unsure, I'll reset a few inches further away. So far, I've not had to do this. Will be more interesting with a new FW with a slide about half again deeper, as well as 2 others. I imagine a broken broom handle, marked the same way will work. :-)
I also make sure all cabinet doors are shut, chairs set properly and nothing has fallen down before moving in or out.
Lyle
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
