pianotuna
Sep 26, 2016Nomad III
Hi,
Low voltage may be what is causing the heating.
30 amps should not be run continuously at over 80%--i.e. you really only have 24 amps to "play with".
An alternate solution is to add a 2nd 20 amp shore power cord for the 2nd air conditioner.
GBuilders wrote:
Thanks for the replies, but I''m considering adding a 2nd AC, but I can't run the AC, WH, without causing the plug to overheat and or trip the breaker. I understand the loads on a 30 amp RV are very tight and I would like to have the flexabllity.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
